I finally got her out to the field for some test flights, with mixed results. I had to pull every bit of the extra weight I put into the nose out to get to a decent hand glide into the weeds. Then with a powered hand toss she still went into an immediate right roll and nose dive. So I added some spacers under the leading edge to increase the angle of attack and motor angle, and tried again. Slightly better - she did have some sustained flight but the sharp right roll took her down within 20 feet, and no amount of left rudder or elevator would keep her up.
So she's back to the workshop for some alterations. First, the dihedral. Since I was reusing a wing from a previous project, the dihedral is only half what the plans called for. Time to fix that - should help address the sharp right roll. And increase the motor thrust angle a good bit - stop the nose dive pressure under power, and a little extra on the angle of attack too since that seemed to help. Yes, it's changing more than one variable at a time, but hey - what's the worst that could happen?
