Please do! I love the F-15. It's either that or the BF-109 WWII fighter for my favorite
F15 build pics.
Note:
1) Move the EDF's up to the wood spar. I suggest 2 x 64mm edf.
2) Use Nerdnic's speed wing build design
3) Glue Transparency film in place before closing your wings for the hinges. Don't glue the hinge moving area. Glue both sides. I usually put glue down, put the film in place, quickly glue the whole wing where I need to and close it up. All at the same time.
4) the canopy is also film done in strips.
5) length nose to tail is 31.5 inches, elevators stick out back a little farther. Body width is 7 inches
6) Wing span in 30 (actual size of a wing measured was 10 inch by 9.5 inch and I found that to small and enlarged the wings)
7) Wing root is 11" width is 11.5
8) Elevators are 5.5 x 5.5 inch
9) Rudder are 5.5 x 6 inch and make the inner side of each longer by 1 inch to glue to the inside of the body wall.
10) Leave an air hole. The way I've built this, air will come in either side of the canopy and cool things and air must leave. Make a hole somewhere...
11) Have fun and make sure your servos are tested and centered before you close the wings!
