I took some real liberties with the hatch/canopy lines without thinking thing through and needed to do quite a bit of rework. Still just a tad too wide as the top foam bends a little different than the sides and things don't meet up just right.
Real happy with how the lines turned out, not at all happy with how the front of the hatch mates up with the fuselage. I think all of the messy work and many glue and rip off of that one skin may have beat things up enough that the gap is way uneven and horrendous (No I'm not going to include a closeup of
that
) I also forgot to glue my skewers in before putting the front skin on, so they don't work too well. Now to see if I can get the front of the windscreen worked out and have the hatch done.
I also think that in the build instructions I'll note to place the hatch on the fuselage and install the front skin flush with the front, then continue on with the second skin and the canopy (if using FB and not clear) - that way the gap won;t be so big. Oh yea - in the notes already but for someone who may remember it from here - glue in the skewers that latch the front of the canopy to the fuselage BEFORE gluing on the first skin
I'm thinking just a few loose ends to wrap up. Two skins on the cowl - or I'm thinking of layering five patterns together without paper and sanding them to a nice shape. Then the guns and landing gear covers for a few details. Cant' forget the modified hatch/canopy to permit installation of a clear canopy. I also still have the issue with the fuselage under the wing that I don;t want to design until I figure if the angle of attack that I baked into the wing position is going to be too much. Oh yea - and mark where the control horns should go. Build #2 won't start until I get a chance to fly this one.
Call me nuts, but I may redesign the wing and try out a few things:
-Extend the fronts a touch and design it so you tape the leading edged together and bend like the FT Simple builds. Need to figure out what to do out where the wing begins to curve back...
-with the above change, use full airfoil profiles in a few strategic spots and make the bottom of the wing curved. That would also serve to clean up the design of the fuselage below the wing.
-make the ailerons full size - meaning part on the top of the wing and part on the bottom. The shallow cut on the split flaps turned out to be easy, so why not?
I know that a lot of people like to just build quick and get it in the air
ROFLMAO: I'm one of those in the summer...) but with this one I'm trying to really reach for prototype design for some reason. I'm just having fun seeing what I can accomplish I guess! Maybe the major wing mods will be after a second build and I get plans put up for anyone else that might want to give it a go...
