what are the wooden blocks forGot the wing innards done tonight. Going to sleep on nav lights and decide tomorrow before I get the top wing skins put on. It's a busy weekend so I'm hoping I'll have it poly'd by the end of the weekend
They will provide support for landing gear - sorry - I guess I should have noted thatwhat are the wooden blocks for
They will provide support for landing gear - sorry - I guess I should have noted thatProbably a bit overkill on thickness but I think my landings at this point need all the support they can get
The 'tubes' provide me with a way to easily get the servo wires in after assembly.
Wing fillets done. I wish I could make them easier to deal with - I think I'm going to really need to take some pics or maybe video on how to make it happen. It's a little sloppy but for the first time ever trying anything like this I'll take it! To note here so I don't forget later, I used the beacon foam tac from the Dollar Store to attach these. The bottoms of the fillets need a major taper to fit the bottom of the fuselage (I put them on in the wrong place and had to move them - not sure why I didn't just recut them...) The actual fillets had a very shallow taper on them and then sanded them to almost nothing on the top and bottom edges and thinned it out quite a bit toward the front. I then peeled off the other side of the paper and formed them like normal (marker rolling across the edge of a tube) to give them the curve. I then did a test fit based on a few measurements that I will need to make a template for. Once it was fitting OK after bending, I marked the edges where the fillet would meet wing and fuselage. I then ran a bead of foamtac right along the inside of the marks all the way around with a hefty bead across the edge of the fillet bottom. I positioned the fillet onto the foamtac, nudging it into place all around and let it sit for 10-20 seconds and carefully peeled it back up, starting from the back, taking care not to tear the front off. I let it air out for 20 or 30 seconds and then repositioned it, pressing the foamtac tightly along the edges, saving the edge where the fillet meets the fillet bottom for last. That I sued a bit of hot glue on, spreading it apart as needed to get the glue inside, but not too much as the fillet would then be trimmed to match the contour of the fillet bottom. A few swipes of hot glue on the pointy front and back to seal things up and this is what we got...
View attachment 219844 View attachment 219845 View attachment 219846
I think it turned out cool but what a pain in the butt!
That looks brilliant!Got the rest of the fuselage done yesterday and spent this evening breathing life into the control surfaces. Unfortunately I stopped videoing a few nights ago before I top-skinned the wingand no video since. I was planning on some sort of build instructions but I guess I'll need to do a third????
Underbelly done - and I actually did get patterns laid out and added to the plans (thankfully). If I do any more video, I'll probably build this again and video it View attachment 220020
Cowl guns in place - they actually built quite easily. One piece of FB wrapped over the top of a single piece with the top edge rounded. Glued in place and let dry for a while (15-20 minutes) (the part was oversized tall) then trimmed it to fit with the bottom angle and sanded for a clean fit. Finished off with rounding of the front.
I'll likely be sticking drink stirrers in for guns...
Another part of tonight was testing the clear canopy parts. Cut them out of regular paper (not cardstock) and laminated them. Going to see if they are sturdy enough or not (others I've done were manila folder stock)
I'm barely starting rc-building and flying. My current enterprise are training on the ez-jets that use the ez-stem power pack, but I'm feeling the urge to go to my scrollsaw this afternoon and cut me a Chinese air force fixed wheel Hawk 75 wooden toy and a Ki-27 Japanese along with it.
I just love old.airplanes, I guess
Spectacular! 👏👏👏👏🤣So I foudn something out as I am wrapping up the P36 build. When I maidened the first one, I pulled the power pod out of my BF109 (stll the original alpha build) and tossed it in my first run P36. If you hadn't read already, it wanted to pitch up on throttle. A bit of down thrust seemed to have solved it. I have discovered another possibility - when I build the original BF109, I goofed on the plans and had the motor centerline 5mm too high. I didn't modify the fuselage of course, so I modified the power pod (the plans have long since been corrected). So using that power pod had my thrust line 5mm lower than it should have been. The idea of having the thrust line go through the CG could possible add up here - it had a touch of downthrust to point the thrust line at the CG - the motor was 5mm low, thus the small downthrust need?
I'm going to fly this one with the thrust line at zero and we'll see how it goes! I can always rebuild the power pod and add that touch of down...
No matter - spent more time tonight getting 'decals' on, building the power pod, and getting the canopy and pilot wrapped up.
By the way, you'd think I would have learned about the spray melting the foam through the poly (my weak thin layer of poly). I didn;t. I ended up having to to a bad job of patching the guns![]()
Awesome build, great paint job!!So I foudn something out as I am wrapping up the P36 build. When I maidened the first one, I pulled the power pod out of my BF109 (stll the original alpha build) and tossed it in my first run P36. If you hadn't read already, it wanted to pitch up on throttle. A bit of down thrust seemed to have solved it. I have discovered another possibility - when I build the original BF109, I goofed on the plans and had the motor centerline 5mm too high. I didn't modify the fuselage of course, so I modified the power pod (the plans have long since been corrected). So using that power pod had my thrust line 5mm lower than it should have been. The idea of having the thrust line go through the CG could possible add up here - it had a touch of downthrust to point the thrust line at the CG - the motor was 5mm low, thus the small downthrust need?
