I know these pics are on the buildruary thread, but they really do belong here first! Wrapped up the basic gear tonight as well as one last bit of artwork. I'm bummed that painting over the silver with clear coat to seal the decals took some of the shiny metallic away
but it's only noticeable on certain angles with light.
Tail-dragger, sure - but I think she needs a tail wheel... There's a 3-layer spine back where one belongs so I think I'm going to be cutting away a space to get something 3D printed in. I'm not going to try to get it tied into the rudder, but then again, the full scale Corsair had a dolly tail wheel!
The bottom of the wing being flat messed with the fuselage bottom but I tried to get a similar look of the real thing for the belly pan
The hatch ended up glue on when I attached the canopy to the hatch base - I popped the front edge of the rear window trying to get the hatch off without destroying the fuselage
Flaps fully deployed! I ended up using a cut down large control arm for the flaps. When I did flaps on the BF109 I had designed a different arm but I figured this would be easier.
One removable hatch...
...and one really spacious battery compartment! Below, that is a 5500 3S battery and it balances out perfectly
It's actually sitting on top of the power pod. It can also more easily sit on its side down in the pod where a smaller battery would be. Note that a smaller batter WILL need nose weight. Did I mention that I have 2814 1050kV motor in the front on a 10x7 prop?
