No not yet
Work has been hectic and I just haven't had time or energy to get things wrapped up. I'd need to go back through to be sure, but I think that plans were 95% there, just a handful of one-offs that I did in a hurry as buildruary was wrapping up, and I never tested updated plans for the DTFB canopy/hatch. Also a retry on the bellypan is in order. I did get a start on modifying the plans to do a P40E for a club member with the modified wing design with a rolled leading edge and have yet to build the test wing half.
I can PM you the plans directly if you want, or I had plans on testing the new wing after this weekend (heading to Toledo swap meet tomorrow, been sick with a nasty cold since Tues) and get them to you next week if the new wing works out...
Just to recap what's potentially not 100% with them:
-FB canopy and hatch
-main wing LE is the normal FT style with no bend. The sizes ended up with the wing cutout in the skins and core having a 3-4mm gap where the LE should have met. The rolled LE should resolve this.
-skin A (very front piece) and the small round ring at the very front of the cowl are likely not accurate, likely would need to wrap front skin and trace proper size for front ring.
-bellypan is likely fine, but it was only made once
Everything else went together well enough with hot glue - although it would be interesting to know how good my lines are with wood glue!
