When you have lemons:
To bail out the Cub (When I go back to build that Cub it will be called War Baby) I was having trouble with I decided to build a wing I have experience with, this is my 3d long wing for a motor glider type. Low power requirements, easy handling, high lift, slow flyer.
This 48” wingspan on this high lift profile wing is folded by removing a .250” strip of the paper along the inside leading edge fold line. No leading edge bevel, no leading edge glue, nothing fancy. The spar is a double thickness .75” X 30” flat foam with a .065” X .5” X 24” balsa doubler in the center between the spar & the lower wing surface for strength & flexibility at the center section where the halves are joined. There is no spar from the ailerons out to the wing tips, the fold provides the needed strength & allows flexibility for maneuvers or high Gs.
Will it flap under high G loads, sure. That’s not unusual for glider style wings. Will it collapse under high G loads, not likely. With the balsa in the center section.
I power these motor gliders with a B motor. That’s about right for training & slow flight. The wings like this one that I’ve flown before like to roll & loop, I haven’t tried to spin or snap-roll one yet due to my entry level flying skill. The last one I built & put on a Simple Stick fuselage had a symmetrical cross section but current isolation rules, social distancing & closed outdoor facilities, including at our club field, have stopped me from seeing if it will fly well inverted.
The fuselage will be approximately 25” inches long, I haven’t designed tail feathers yet & I might extend them beyond the fuselage somewhat. All I did was cut away the parts of the Cub fuselage that I was having trouble with & flipped the fuselage design over upside down. The wing will be mounted as a high wing on the flat surface that would have been the belly of the Cub.
Figured I’d make Lemonade.
