Quinnyperks
First time of 2021First time, really?
That's not much of an answer. Did you fly 1000 times in 2020?First time of 2021
Probably a few dozen tripsThat's not much of an answer. Did you fly 1000 times in 2020?
Ah there you go. Good luck flying.Probably a few dozen trips
ThanksAh there you go. Good luck flying.
Wing secured in place, hinges fitted to all control surfaces and all edges rounded off with an iron on the wing and tail.
Horizontal stabiliser is only temporarily installed, need to design a brace to connect two halves of the elevator.
Rebuilt the power pod following yesterdays confusion regarding the thrust angle, I also rebuilt the canopy as I wasn't happy with the fit of the first attempt.
View attachment 197793 View attachment 197794 View attachment 197795 View attachment 197796
Finishing this project will be a little delayed, I decided to go for 500mm servo extension leads to avoid the mid wing hatch. Unfortunately they are only due next Friday. I am sure there are plenty of other jobs to do in the mean time.
Had another thought, to avoid having to add lock tight on the prop nut, as the prop is going to be rotating CCW. I am planning to fit a prop saver Problem solved![]()
Have you tried using credit cards for control horns? You can get blank white ones on Amazon for a couple bucks.Having a night off from building, I was working on the Otter this afternoon so fancied a break.
Made up 4 plywood control horns, time consuming job using a Dremel multi tool. Finished the firewall and mounted it onto the pod, used reinforced tape to hold it in place with hot glue, just to make sure.
Realised I had forgot to mount the vertical stabiliser servo with an extension lead before I mounted the stabiliser on the plane, so that's going to be a testicle ache feeding the cable through later.
Feels like the Otter projects on hold now, I am basically waiting for the extra long servo cables to arrive and they are only due Friday. In the mean time thinking of building another Tiny trainer this week. Not decided yet how its going to look as I am planning to modify/upgrade it a little.
STILL GOT TO CUT THEM OUT EVEN WITH PLATIC CARD, I NEED A LASER CUTTERHave you tried using credit cards for control horns? You can get blank white ones on Amazon for a couple bucks.
Stop shouting.STILL GOT TO CUT THEM OUT EVEN WITH PLATIC CARD, I NEED A LASER CUTTER![]()
it's looking awesome!!!!Finally was able to get out this afternoon and get some more foam, the storch stands on her own two legs now!
And she is by far the largest I’ve built.
(Grainy image due to old iPad and poor lighting)
it is so much easier than plywood out of gift cards it just takes a couple of minutes to make one, compared to the plywood ones which took me over half an hour for four.STILL GOT TO CUT THEM OUT EVEN WITH PLATIC CARD, I NEED A LASER CUTTER![]()
It only takes me like 30 seconds to cut out 4 of them. A scroll saw is a life saving toolit is so much easier than plywood out of gift cards it just takes a couple of minutes to make one, compared to the plywood ones which took me over half an hour for four.
Ian, U just gave me an awesome Idea. I luv what U did to the Otter. While looking at it, I light bulb just went off. I have this chuck glider that I just bought and was wondering what to do to power it. A 64mm EDF mounted on top. I was going to put it off for awhile, but now I think I can do this one quick. Thanks!
I don't have anything fancy. Just a hobby blade/exacto knife. With a little steel straight edge as needed.What do you use to cut them out of plastic?
I use sharp scissors.I don't have anything fancy. Just a hobby blade/exacto knife. With a little steel straight edge as needed.
