Maybe you are talking visibility, in which case others have addressed that.
But if you are talking stick and plane orientation, depending on whether it is coming or going, I still use this little trick sometimes. Point your antenna parallel to the direction of flight. Might make more sense if you grew up with telescoping antennas on 72Mhz radios. So if the plane is coming to you from the right, you sort of look over your shoulder at it, with your transmitter and part of your body facing to the left. Once you've gotten comfortable with stick-vs-plane orientation, you'll probably stop, but I still find myself doing that body english.
If this is not what you where asking about, the jn the classic words of Gilda Radner, "Nevermind".
