Catching up.
The tail bits have been trimmed and sealed, the hatch built, excess paper trimmed, and the elevators joined. One nice thing about this papier mache is that it sands like wood.
Next came the iterative process of sanding off extra glopped paper, sealing bared spots, and applying spackle. That took a few days.
Now, it’s time to put the tailplane on….once the weather warms up. As of this afternoon, it was 35F in my garage – too cold to work! I have a space heater, but it isn’t worth spending an hour (or two) warming the garage for a few minutes work and keeping it warm whilst the clear Gorilla Glue cures.
My FrankenJig II is a straight bit of plastic (Melamine?) coated particle board, drilled and tapped for 1/4 X 20 bolts and with two strips of aluminum stock. The tapped holes hold the verticals, which brace fuse sides; the aluminum strips hold brackets that lock onto wing LE and TEs. My usual trick is to use flat-bottomed airfoils, designing the models so the flat bottoms are parallel to the tailplane bottoms.
What makes the Mambo different is that the plane has about 2 degrees positive incidence on the wing. That's because it was designed for single channel radios, where it would always climb under power (Going to omit a long explanation of single-channel acros! ).
Just remember the full-scale rule that throttle controls altitude and elevator controls airspeed; with a plane like the Mambo, climb under power, then throttle back to maintain altitude. Use elevator and more power, as needed, for acros, but there's no reason to keep the throttle at full all the time.
  • 25 Tailplane and joined elevators.  Note using blocks to hold in place without denting, and Sa...jpg
  • 26 Typical surface edge after sanding. Seal with Glue Glop or straight glue.jpg
Adding the tailplane/horizontal stabilizer and the fin/vertical stabilizer are two of the most important steps in building a model that will fly well and not need constant corrections.
My FrankenJig II is more complicated than necessary, but it does the job of holding everything in place whilst the glue dries. Today, I locked the Mambo into the Jig and glued on the tailplane. Once the glue has cured, I'll cut open the fuselage top and glue in the fin.
Note: Those are scrap blocks of marble transom, from when we renovated a bathroom. The stuff is heavy, FLAT, and can be cut with a hacksaw. I used it to keep the model from bouncing upwards whilst I sanded the tailplane slot.
No, not between the landing gear legs, but 2 1" wires about 1/2 long and solder about 1/2 way up each leg (from your picture) so you are hooking from the ski to the backside of the wire so it is under tension. Now take 2nd rubber band from back part of ski to 1" wire. When hooked, ski is parallel to wing chord and if you pull up or down on ski, tension of rubber bands bring it back to parallel.
Do that and show photo of setup before you fly.
Hey L Edge Is this what you meant?
Всем привет я начал проект F-18 Super Hornet заново. Предыдущий сгрызла собака, пока он был на работе на вахте. Ну и внес некоторые изменения по сравнению с предыдущим проектом View attachment 246571 View attachment 246572 View attachment 246573 View attachment 246574 View attachment 246575 View attachment 246576 View attachment 246577 View attachment 246578
Закончил проект
Flyingshark
Good eye! It is an FMX-4 sized for power pack A!
Continued working on the Facetmobile last night and got the first prototype about ready for a maiden! :D
I've already identified a bunch of changes I'd like to make, so I'll probably build a more polished version afterwards, but this way I can validate that the general configuration with an 1806 and 6" prop will fly. I'm not very concerned about TWR, but I am interested to see whether drag will be a problem...
