Hi Everyone,
I'm in the process of completing my first Anycopter quad which l have ordered the props as listed by Chad. I noticed the props were all the same type i.e. Standard Rotation (RH Rotation). I've noticed that Chad's prop list didn't list any RL rotation props?
Should l order some RL rotation props even though they weren't specified on the parts list?
OR
Do l simply use two of the existing RH props and mount them with the prop lettering facing the ground applying the following;
Clockwise motor rotation = Standard Rotation (RH Rotation) prop mounted with the prop lettering facing the sky
Counter clockwise rotation = Standard Rotation (RH Rotation) prop mounted with the prop lettering facting the ground
As you can tell, l am very new to this in which this is my first quad copter build which l would appreciate your help for succesful takeoff.
Thanks in advance
OR
Thanks in advance
