JeromeAu
Now have all the parts to make the XF VIPER F-16 EDF, and did the graphics design for the skin.
Specifications:
1 x 70mm 12-Blade EDF Unit
1 x Aerostar 50A Electronic Speed Controller
1 x Turnigy 2226-3000 70mm EDF Outrunner
4 x Turnigy TGY-1551A Analog Micro Servo 24T 1.0kg
1 x OrangeRx R610V2 Lite DSM2 Compatible 6CH 2.4GHz Receiver
1 x Turnigy Graphene 2200mAh 4S 45C Lipo Pack
2 x Servo Extension Lead
1 x Servo Y Lead.
1 x Multirotor LED Brake Light Set, Green, White, Red
I made some changes to the VIPER F-16 plans for the build, by adding Ailerons, so i need 2 servos for and the other 2 servos are for the Elevator.
The Multirotor LED Brake Light Set, Green, White, Red
Is been used for the after burner, and mixing it with the Throttle on to a channel I got to bypassed the Green so the Red and White LED's glow.
My goal is it to stand out when flying and been Red it seemed appropriate that Deadpool more likely the one that fly a F-16, and rather happy the way the skin worked out. and have add a 5mm bleed so the skin can cover the edges.
Now to make it, plans are printed and next will be cutting the parts out from the Foam board.
