Hi guys,
a month ago, I finished my Tricopter build (I posted a thread called "First Tricopter Build - Advice welcome!" in the Multirotor newbie section). Since then I'm having a ton of fun, flying nearly every day. Even in strong winds, it is so nice to fly!
I knew before I build it, that at some point, I'm gonna buy an FPV kit. With these big steps I'm making (I really have the feeling that I get better with every flight I do) I think I will be able to mount FPV gear in the next couple of months (1-3 months, depends on how often I'm able to fly) when I get the money for it. I'd rather wait a little longer and spend a bit more than buy some cheapo gear and losing the fun with it after a couple of weeks.
So I'm searching for good FPV gear (glasses, cam, and TX) for a FPV beginner - and don't yell at me: I know I have little flying experience and should be practicing a bit more before starting FPV, but I like to inform me in advance, so that I can search for a good deal for some time.
Do you have recommendations for when it is a good idea to add FPV gear to a Tricopter? Something like "if you're able to fly the basic manouvers and do not get confused with directions and can do some loops and flips, then FPV is a good next step"? I know that one has to know that for himself, but I wanna know if I'm heading in the complete wrong direction and should be practicing a ton (like a year or so) more before even thinking about FPV...
I mainly looked at the fatshark goggles, because they are so popular and readily available, and they have kits including everything one needs. It seems like I have 2 viable options with fatshark:
Fat Shark Predator V2 - cheaper solution, smaller FOV
Fat Shark Attitude V2 - A bit more expensive, bigger FOV, connection to external sources possible
With "only" about 50€ difference, I'm heavily favoring the attitudes, as I said: I do want something that I don't grow out of too fast and I have the feeling that a greater FOV really can make a huge difference. I think Dominators are way to expensive for what you get with them, or am I wrong? They are the way to go if one wants the best possible goggles and doesn't care about money as much?
Please note that I'm living in germany and from what I know, you're only allowed to use 25mW TXs with the 5.4Ghz band... I'm using a Spektrum DX6i, so I control via 2.4Ghz.
So my questions to you guys are:
Are the features and greater FOV of the Attitudes worth the 50€?
Are there any other good alternatives that I forgot? Although I have to admit that I often like the "mainstream" alternatives a bit better with these things, as more people are able to help you with problems that could occur.
What can I realisticaly expect for the range of a 25mW TX + Fatshark RX when I use circular polarized antennas? - I've read anything from signal loss after 100m to guys that pretend to be flown over 2km. I'm thinking of about 250-500m, is that realistic?
Should I really absolutley stop thinking about FPV in the near future because it would be totally dumb to start it with only 2-4 months flying experience? - I hope not, because I'm absolutlely fascinated by it!
Do note the smiley of this thread: It has a smile on his face with his goggles. That's what I want, too!
Thanks in advance for any tips you give me. If this will go as well as it went with my Tricopter build, I can't be happier!
-1387
-1387
