Beginner needing advice
tomlogan1
I am a new flyer since July. After building and destroying foam board planes, and not learning to fly, buying and destroying ready to fly planes, and not learning the fly, I finally bought an EPP Foam trainer to build, the Crashtesthobby Albatross. I have crashed it many times, but never damaged it, I built it poorly, and figured out how to make it better, the main thing is that survived all of my iterative learning and iterative building. It can fly slow! And in the wind. So I can learn. I'm hoping that after the winter, I'll be good enough to fly some of the foam board kits from FliteTest that I have bought and built but never dared to fly.
None of my problems are anybody my own fault. However, I think every flying club should have one of these EPP foam with lamination trainers. They're unbelievable.
I have a busted up tiny trainer, I'd kind of like to build a fuselage out of the EPP foam, and try out the two mostly intact wings. I just got some foam packaging that just might let me do it.
I'm very interested, in what, FliteTest, will do with their nice and fancy CNC foam cutter.
Could they make an EPP foam fuselage for the Tutor Foam Board Wings?
A "Foamy Tutor"?
I've flown the Albatross for about 5 years. I started with the polyhedral wing and taught myself to fly. I have built the aileron version as well and it, too, take quite a beating but sill flys well. The guys at the field call the plane "old reliable" and it is. It's been crashed, broken in half, reglued been converted to a twin motor configuration and back to a single motor all the while being an easy plane to fly. The Tiny Trainer, Scout and the Spitfire are all easy builds and great flyers. You can progress from there at your own pace and building your own you get to know the eccentricities of your plane.
It really helps to fly a beast of a plane when you first are learning. The foam board crashes can be sooo demoralizing, especially for the young that have never heard the "virtue" of building and crashing with Balsa and shrink films. :) Crash your Albatross as many times as you want. Easy fixes and will still fly like normal.
It is about 6 of one or half dozen of the other, most trainers in balsa do have tricycle gear. I believe this is because less chance of breaking props on landing and a bit easier to land. Less to deal with when taxing and keeping the tail down with up elevator, and rough runways tri gear is easier to handle..
Thank you. Helps with a Tudor MR2
