Most of us know that it is possible to bind multiple receivers to the same transmitter simultaneously. This is almost a necessity with a single memory transmitter such as a Dx5e. Of course, you would only try to fly one of these at a time ... or WOULD you?
Challenge: Bind two planes, quads, whatever simultaneously to the same transmitter (model memory). First, get one high in the air ... cut the throttle ... connect the battery to the second aircraft ... then open the throttle and take off! Of course, whatever you do to one aircraft happens to the second! But ... I think you could fly and land both in one piece if you were judicious about your aircraft selection. Perhaps aircraft #1 would be a slow, underpowered three channel trainer while aircraft #2 would be a quicker and nimbler one. Thus, you might manage to manuever aircraft #2 into the air and back again before aircraft #1 crashes. You'll also need to cut the throttle long enough to remove the battery from aircraft #2 before aircraft #1 crashes.
You'll need A LOT of room, or a lake, to carry this out.
I CHALLENGE YOU!
I CHALLENGE YOU!
