Do You Want To Build a Bird of Time Too?
FT STYLE to the EASY way:
Build a Simple soarer, but change the outer wing shape and empennage to match the Bird of Time.
History: Last Summer at FFE 2018 I brought FT-Simple Soarer (SS) Plans to build one and enjoy at the festival. I was excited to use the FT-DTFB then I would have a SS I could fly in all weather. as I was starting I thought about how much I loved the Bird of Time (BOT) from the episode FT/Josh Bixler did long ago. I had just been staring at them and disappointed there were no Kits available. The Idea Struck me - just change the wing shape and Fuse a bit and make one of you own off the SS. So I did!
Build Method: Build a Simple soarer, but change the outer wing shape and empennage to match the Bird of Time. I curve the tail boom and tucked the servos where the 18" landscaping wire pushrods could reach. Lastly I build a Power pod shaped like a glider pod. pulled paper off the bottoms to curve it to the lower profile. - Success! I then Taped the wing and made it beautiful, then had every FT personality I ran into sign it. It was the one plane I have never managed to bust up beyond all recognition.
In-situ:
Top: Bottom:
Experience Tip: Don't choose to colors have the same hue. As they recede into the sky they grey out to the same color.
Results:
It flies manageably. It has yet to fly like I want, but there are two things I love about it. It's beautiful shape, and the outside pod gives more room to place the battery and ESC.
SS-BOT Plans:
Reserved
FoamyDM style Build
This "stupid" plane has been on my mind since... I searched and found nothing in the Scratch builders thread here where someone attempted a FT style or DTFB build. That's what this thread is really about. so Here I go.
Mission Statement: Using build techniques I have learned this past year I will attempt to build a DTFB replica that is as simple to build as any FT build. I want to build it with Windows through the surfaces. to save weight and the skin will be Dollar tree cellophane and wrapping paper.
Limitations: - Use accessible 6mm Carbon Arrow shafts for spar. the rest - Foam.
The original build is 1.16kg / 41 oz. RTF, according to the article. As the model will be close to 6 full sheets I suspect it will be close to the same.
I'm starting with the set of information located at outerzone.co.uk. if you want to build a balsa scratch build for stick you have... you can stop reading.
Original Specifications:
Project start -
Plans: Every repeatable project starts with plans.
This is my current progress:
This is looking to be 6 1/2 sheets.
Almost a complete seven
FULL-Sized PLAN Set
This Plan doesn't include an estimated CG of 4" behind wing Leading Edge.
Maiden Video
Listen after the launches at 34s and 3:50m.
Prior repairs from first maiden:
This is after I reinforced the sides with Carbon fiber tubes. And found suitable nose weight. Over 1 lb! (Added to the 5000mah 3S bat. Weight.)
While not the smoothest starts, it shows this foam bird behaves just like the balsa. A gentle responsive soaring glider. Build your own! Now you can.
In-situ:
Top: Bottom:
Results:
SS-BOT Plans:
Reserved
FoamyDM style Build
Project start -
FULL-Sized PLAN Set
Maiden Video
