UPDATE:
I have been out of foam and pretty busy the past couple days so I didn't get to do much more on this project. I went to the local DT and bought an entire box of foam board, so I *should* be good for a little while.
I have redesigned a few things and will begin the wing assembly tonight.
Here are some pics of the new design:
I felt the wingspan was just way too big for not having the ability to remove it - so now it will have the same polyhedral design, but will only be 44" long.
I have had bad luck in the past with small stabilizers, which is why I initially made these huge to begin with. I have now dialed down the size for both the vertical and horizontal stabilizers and hopefully they will work out okay!
I have also shortened the length of the plane by 4", but only with the "tail boom" type area. The main body of the fuse will remain the same size as before.
I think the double tail idea is a good one, but looks like it would add a tremendous ammt. of tail weight to a design that already needs additional weight ON TOP OF a battery all the way in the nose.
