Build Help wanted
Captain-Pudding
Hi everyone,
I'm trying to put together a fpv build for myself but needing some help. I'm new and not sure if this will all work.
Question 1:
I have the Flysky FS-i6X with FS-iA6B Receiver, Will that work with any Flight controller? I'm currently looking at MAMBA F722S F7, see under question 2 for link. https://www.amazon.com/gp/product/B0744DPPL8/?tag=lstir-20 and https://www.amazon.com/dp/B07GBQ94GZ/?tag=lstir-20
Question 2:
My current build is this, please let me know what y'all think. I'm just looking for a beginner fpv quad, that I can have some fun with.
Flight Controller :https://www.banggood.com/MAMBA-F722S-F7-Betaflight-Flight-Controller-OSD-5-or-9V-2A-BEC-and-F50PRO-50A-3-6S-Blheli_32-Dshot1200-FPV-Racing-Brushless-ESC-for-RC-Drone-p-1490805.html
Frame: www.banggood.com/IFlight-TITAN-XL5-HD-Spare-Part-250mm-3K-Carbon-Fiber-Frame-Kit-Compatible-DJI-Air-Unit-for-RC-Drone-FPV-Racing-p-1667368.html
Video Transmitter: https://www.banggood.com/RUSH-TANK-II-V2-Ultimate-5_8G-48CH-Raceband-PIT-or-25-or-200-or-500-or-800mW-Switchable-2-8S-VTX-FPV-Transmitter-for-RC-FPV-Racing-Freestyle-Nazgul5-Tyro129-p-1707214.html
Antenna: https://www.banggood.com/A-Pair-Rush-Cherry-RHCP-MMCX-Right-Angle-1_2dBi-5_8Ghz-FPV-Racing-Antenna-for-RC-Drone-p-1484515.html
Camera: https://www.banggood.com/Foxeer-T-Rex-Micro-1500TVL-Super-Low-Latency-Super-WDR-4-3-or-16-9-PAL-or-NTSC-Switchable-FPV-Camera-Support-OSD-and-Menu-Remote-Control-for-FPV-RC-Racing-Drone-p-1756536.html
Motors: https://www.banggood.com/4-PCS-iFli...-Motor-for-RC-Drone-FPV-Racing-p-1686952.html
props and goggles, I'm not sure and would like some suggestions.
Thanks!
Ironhaigen
5in frame with fairly big motors and 4s - 6s (I assume)? For a beginner? Send it!!!
The only major issue I see is the rx.
That rx looks like a plane rx (for servos). You’ll likely want a sbus type rx. Never used flysky but I use spektrum and they are different (plane vs quad rx).
Other than that it should go together and fly. Its gonna be fast. It’s just maybe a bit overkill and pricey for a first build IMO.
JasonK
Participation Award Recipient
Your going to want to get a serial RX, that can only do ppm. I don't know if any current FC software supports that (and if they do, I wouldn't expect them to do for long, it is an ancient 'method' for data and doesn't let you get telemetry, extra channels, etc).
JasonK
I thought iBus and PPM were both serial protocols, not sure if the FC can read them.
PWM for is for servos.
PPM is bascially PWM but all on 1 wire sending 1 pulse after the next and is very much 'legacy' as far as protocols go.
I didn't see iBus out on that FC, if it has it, that is probably ok.
