• NOTE: The forum is currently undergoing a planned upgrade. Certain content or features may be missing or limited until the transition is complete.
carbon fibre adhesive
novaz
I don't have the correct oven for bonding carbon fibre but was thinking that maybe an Epoxy or Gorilla type adhesive would work I am making a fire wall for my new motor to go in the carbon cub any recommendations.
Thanks
Fluburtur
Cardboard Boy
Epoxy should do that job, it is usually what is used to make carbon fiber in the first place. Sand the surface with coarse sandpaper to give it good grip andit should be good.
Bricks
AS mentioned above sand with coarse like an 80 grit and clean clean clean using either alcohol or lacquer thinner.
