Well, crap. The Cessna may be cursed as it just doesn't want to stay in the air. It's not obvious at first in the pic below, but the nosegear is collapsed and the front of the plane is being held up by the partially broken prop. The muffler pipes are also bent/broken.
But for some good news, the previously made repairs after the first maiden attempt held perfectly, and there was no additional damage from today's attempt at flight.
So weather was good (a bit hot, but no real wind) so I took the plane up to my dad's field to fly. Since it hasn't been flown since the first maiden, I fired it up without wings installed and taxied it around the field for a while. Once I confirmed the repairs were solid I installed the wings and sent it up.
Good thing there is a long runway at this field, as the plane is VERY heavy. The plane's designer calls for a 2.5 to 4 cubic inch engine. My 58cc is 3.5 cubic inches which should be enough. Well, it is, but just barely. It flies scale, like a Cessna 150/152 should, but some additional power would certainly be nice for getting airborne.
After getting some altitude I throttled back a little to do a couple circuits of the field. It was flying very nicely - very stable and controlled in the turns. That's when I found the throttle wouldn't advance again, and I was stuck at about 70% throttle. I wasn't sure what the problem was at that point, but the best plan was to bring it down and check it out. Circling around a bit more I lowered the throttle some more, and again it would only drop, and not advance. I added a notch of flaps to give me a little more lift at the reduced power and lined up for a good approach to the runway. When I knew the plane was clear of the brush at the end of the runway I cut the throttle to land.
Remember when I said the plane is heavy? Well, without power it dropped much more quickly than expected, and even with full up elevator it came down HARD, and the nosewheel hit first. Turns out the strut for the nosewheel doesn't like that kind of abuse and it broke loose and bent heavily, letting the engine dig into the ground. It appears the engine is toast, as the muffler took a lot of the impact and I think in-turn it damaged the cylinder. My assumption is that the throttle servo (which is new) failed.
So, what to do with it.... It could be repaired without too much headache, and a new engine installed (I have two more Turnigy 58cc gassers in my stash). However, it's way too heavy as-is, and to do it right the plane would need to go on a major diet which would include stripping the fuselage (again) and doing major surgery. At the end of all that work it still wouldn't be exactly how I wanted it to be. I love the color scheme of the plane and think I'll just end up buying the plans and building the replacement from scratch. I could drop in another Turnigy 58, or a Zenoah G-62. Building a replacement would also let me skip all the work I was facing on the wings and struts (only the fuselage and electronics were re-built on the plane). I'll let it rest for a while before making a decision.
