cloverstone
Im still pretty new to all of this but I built a simple frame while I was saving up to buy a carbon fiber or G10 frame and in the end I love it so much I don't have any need to upgrade, at least until I get good enough for some detail to matter to me. So with no metal fasteners (only zip ties) and only two basic tools to build it (hack saw and drill) I thought this may be interesting enough to share and maybe get some ideas to improve it or inspire someone else with some of the unique(ish) design choices. I recognize that there are probably some bad choices as well but I was trying to keep it simple to build, cheap, light, and able to handle a crash. So far so good it seems to fly extremely well.
Some of the more interesting features are the landing gear made from the caps off of baby pouches and the basic frame is made from two pieces of 1/2" wood glued together and pressure fit into two pieces of aluminum u-channel. I also have the esc's shrink wrapped directly into the u-channel with tape covering the aluminum and I used copper strips on the bottom of the wooden center piece for makeshift power distribution. Lastly the motors are zip tied to the landing gear with a hole drilled in the top of the aluminum to allow the bearing and shaft to not sit on the channel.
