Well in my quest to get my needle cutter working yesterday I managed to give myself a nice 2" cut on my hand. I went with Moebeast needle retainer on the bearing and was slowly ramping up the speed (while holding the cutter in my hand) when the needle must have bound up, bent and managed to come out of the guide. Now it was a nice weapon, caught my hand before I could cut the power. Not real bad, no stitches required, but did need gauze and tape to stop the bleeding.
In review (after reading Jason's article in fine detail) the washer I was using to space the bearing likely covered the outer raceway causing a bind which eventually led to the failure. I discovered that the extra shims that came with my Quad motors work perfectly for spacing. will make another attempt tonight, this time not holding it in my hand.
Jason,
Question for you if you are lurking. Do you have a design of you pre-guide bracket for the new MPCNC mount? The onshape file I found was for the quick change mount. My motor is different so the I need to modify the guide position which I did before I realized it was the quick change setup.
Thanks,
Rob
Jason,
Thanks,
Rob
