Well, finally...
my Foam Ripper build has progressed to the point that I can begin some testing and fine-tuning… first, the obligatory crown plot...
and then a brief run-up of the needle-cutter, with slip-on flywheel...
Currently using the 32″ x 80″ interior door for the work surface, I found that the roll-around wire-shelf unit didn't provide enough support, so it now sits atop a 30" x 60" folding table...
Squaring the gantry...
Could probably use a smaller servo tester...
As CNC machines go, this may be one of the easiest machines to find room for… it can be made “knock-down” for portability and/or storage. The bed needs to only be large enough to allow for cutting to the extremes of a sheet of DTFB, or whatever sheet material you want to cut. The rolling gantry is easily rolled off the bed, is not-too-heavy (20 lbs?), and will stand up in a corner. The belts are simply clamped along the edge of the bed for use. The bed is stored away like any other panel. Saw horses or a folding table hold it all up in use. No computer required to operate, the LCD controller and electronics can be attached to the end plate… so it stores with the gantry.
This has been a fun build. Eventually, I plan to down-size the work-surface and move this machine into the bedroom I’ve set aside for hobby storage and additional work-area. Cutting foam with the needle cutter is not terribly loud and generates little debris so hopefully it will be happy there, not occupying “center stage” in my living area…
-- David
