Looks good David. I was just shocked at how much that polyshaper costs for what definitely looked like a similar or lesser machine. Personally I consider proprietary software a big reason NOT to invest in any given bit of hardware
I'm still around...just haven't had much time to play with my machines or do any flying still. I had my back room cleaned and was ready to do some minor remodeling to make room for my CO2 laser project...but then COVID-19 hit and the person who was going to help me with the construction went back to Alaska to ride it out. Now my back room is a mess again since it's doubling as my office as well as "hobby room" and the summer heat has hit so I'm not in the mood to go cutting holes in my outside walls for a few more months.
I did manage to get a new pull down staircase installed in my shop and that let me get a bunch of junk down from the attic up there and out to the trash, which made room to move some of the stuff that started to clutter up the downstairs but wasn't junk up into the attic. I still don't have the shop clean enough to go do projects out there again...but at least it's clean enough I can walk around out there and make progress on cleaning. But - since I can't arrange any play dates for my daughter I don't have much time to be alone out there cleaning so it's slow progress.
I've been spending a lot of time since March playing radio again to keep me sane/busy. I assembled a
20m FT-8 Phaser back in January and designed and 3D printed a case for it (which I posted about in one of these threads but I can't remember which.) Then started having fun making contacts with it using some temporary portable antennas. Was amazed at how well it was doing with just 4w of power and minimal antennas...so when it became apparent lockdowns were coming I got a nicer wire dipole and strung it between the peak of my office and a pole mounted to my carport. It's only up about 25' but made that 4w even more effective. It was starting to look like I may even be able to get a QRP (low power) WAS (Worked all states) award...but...couldn't leave well enough alone.
I realized that while it was designed to operate on a fixed frequency with a button to switch to an alternate frequency...the way it was built there was no reason it couldn't also be frequency agile only the "brain" was limiting it. So building off work someone else was doing I pulled out the PIC chip brain and patched in an arduino UNO with LCD panel:
It worked. I was able to tune it to different portions of the 20m band! For FT-8 you don't need this ability....but it's still nice to have since you can shift your frequency up and down slightly to keep your signal in the "Sweet spot" of the transciever within the 3k section of the band used for FT-8.
But the UNO was a bit clunky. And the Phaser runs at 3.3v so I had to use a level converter....Next I swapped the big clunky LCD for a OLED display and ditched the buttons since the end goal was to let the FT-8 software on the computer control the frequency over USB anyway:
Better...but the UNO is still too clunky. I got it running on an Arduino pro mini and on an arduino nano. The pro mini was nice since it ran at 3.3v. But it has no native USB ability and needs a separate FTDI adapter which I didn't want to deal with. The nano is smaller and has built in USB...but...runs at 5v so needs the level shifter. So I wasn't super happy with either of them.
I'd been wanting to play with STM based boards since they're now supported in arduino and the Adafruit trinket M0 caught my eye. Not much I/O - but I don't need it for this. Built in USB, Tons of memory, more power than the arduinos (not that either is needed...but memory was getting tight once I added the libs for the OLED) cheap at <$10 and tiny so I could build it right into the case I designed.
Unfortunately I'm having issues with getting the trinket to work reliably and can't figure out why. And while hooked up a frequency counter to track down the issue I slipped a shorted out something I shouldn't have letting some magic smoke out of the Phaser
While I worked on figuring out what happened to the phaser I got my stimulus check and decided I was having enough fun with radio having a real antenna up again that maybe I'd splurge and get a new radio. Saw that the Icom 7300 is a pretty amazing rig and it was on sale for $950 with an additional $100 mail in rebate....which was an offer I couldn't say no to:
And this radio has blown me away. Just incredibly how much radio it is for the price. I'm now just 1 state away from completing that WAS (no longer all QRP unfortunately...but about 60% of it was QRP...then rest I bumped my power up to 25w since I can now.) I'm also <6 states on both 40m and 20m from having WAS individually on each band. If the one contact I had in Maine would QSL I could claim that WAS...until he does I keep listening for one more Maine station to contact and seal it! I've also worked almost 30 different countries since Late March.
Considering that it's the bottom of the solar cycle right now so radio propagation is at it's worst I'm pretty happy with that
Also gave in a treated myself to a new Fluke DMM which let me finally finish the 50w amplifier I was building for my other QRP radios:
That's the amp in the lower left.
So...been having fun pushing electrons and RF around...but I'm really itching to melt more plastic and blast some photons at things. Just...unlikely to make much more progress on that until after summer now.
I actually seriously considered one of those little mini mills just for fun since they're so crazy cheap now....but....I can't think of many projects I can do that are smaller than the 4"x6" working area they have. And I don't want that kind of noise and dust in the house and if I could go out to my shop I have the MPCNC waiting for me. (which will probably get an upgrade when Ryan finishes the new update he keeps teasing.)
But basically still around and still keeping busy - just not making much progress on projects that are on topic here
