Have had some nice results in cutting EPP with the needle this afternoon ... also set the motor to more "high speed" and did the tests with Depron again. ---> The bending wire has some resonance points by differnd motor-speeds - it seems to be a good idea to use a frequency outside of such a resonance point - the cutting will be more precise! I will test an ESC with Governore mode for this to optain a fixed speed.
Two more pics:
The CNC mill with the needle cutting head
http://www.jokr.de/cutter/cutter-15.jpg
needle cutter at work
http://www.jokr.de/cutter/cutter-16.jpg
You can see the parts coming out of the Depron sheet almost by itself.
The next goal is a (nearly) professional grade version (metal - no wood) of the cutter-head...then we can start cutting small planes for indoor flying
Thanx to all here for this great idea (especially to David)
Joachim
Two more pics:
Joachim
