Michael9865
I recently used the needle MPCNC to cut MPF. I was impressed with how smooth it cut compared to DTF. I had the needle at 5,800 rpm and 500 mm/m.
The MPCNC do not like cutting past about 32". MPF comes 24"X48", so it garbled to cuts over the last section. I made sure that the printer bed in Repetier and Estlcam. So I had a lot of waste.
The pieces stayed in place when I lifted the sheets off the print bed. I started to use a blade to release the cut parts, but I noticed if I bent the sheet on the cuts the parts released and fell out. I guess the needle did a little melting as it cut. I also had to replace the inflation needle because the needle section started rotating away from the head. It was a little bent so it caused some of my straight lines to be a little wavy.
I also added David's cotton and light oil addition to the top of the inflation needle. That helped the needle temp and also changed the sound that the needle head makes while operating. Thanks David for the great idea.
Over all I am happy with the Needle MPCNC. It definitely helps an old fellow with poor grip and problems with his hands going numb.
