Import the pdfs into inkscape, then use this plugin to convert it to gcode: Select the desired geometry, go to Path -> Object to Path, then Extensions -> Generate Laser Gcode -> J Tech Photonics Laser Tool.
I downloaded the PDF plans and used a scroll saw to make the templates. I then hot wire cut the sections and assembled with a 70mm EDF. The images below show the model during the build.
