agupt108
Is it possible to make a two wheel landing configuration like with a tail dragger or such for an edf jet like the ft viggen? Thank you!
Also, can you use the FT battery splitter included in the power pack to connect two lipos into series to make two 2s into a 4s? And last, I have two 2s (450 mah each). If I wire the two in parallel that should be enough to power the simple cub right? Is there anyway I can calculate flight time based on that?
