Hi guys!
I´m almost done!
Today was soldering day, I solderd on the servowire extensions for the enginenacells.
As you can see i have two differend minus cables (black and dark blue)
This is caused by the destination of these cables.
One part is running to the RX and one part is running to the Arduino.
All my servos in the nacell are controlled by a Arduino, the RX just controlls the ESC.
I also solderd on the main-powercables.
They are 2,5mm² in thickness so they are ideal for 25 Amps (I have 25A ESC´s build in).
After i had the nacells mostly done i continued with the tailsection.
I had to build a Y-connector for the elevator and extend the cable to the front.
To build a Y-connector i used a little breadboard peace and a few pins (comming with an Arduino).
This Y-connector or Y-harness is all made from scrap so i really don´t understand why these Y-harnesses are so expensive!
Anyways, i solderd it together and pluged in the plugs from the two elevator servos.
I placed it in this little door i made before because i really don´t have any place to work back there.
Then i realised that there was a screw which blocked thelandinggear so i removed a bit of the screwhead.
The next step will be to finnish the secound nacell, to glue on the nacells and to mount the gear.
I think i´ll be finnished in the next week (finally
See you!
Jetcrafter2000
