Part | Weight |
WingSpar - 18" wood rod | 30g |
Tail boom - 12" wood rod | 20g |
4x 5g Servos (flaperons & Vtail) | 20g |
2x 14g Servos (Motor Pod Tilt) | 28g |
2x FT 1806 2280kV Motors | 36g |
2x FT 20A ESC w/XT-30 | 56g |
1300mAh 3S w/ XT-60 | 122g |
F405 Wing Flight Controller | 30g |
2x Servo Extensions | 10g |
my goal is specially to _not_ have separate hover and flight motors, to use only 2 motors, and not have a tail sitter.i have higher belive on such ideas as here, where fans in wings do the VTOL...
I got v0.5 of the tilt mechanism working in my hands. Still needs a few bits fine tuning of how stuff fits/etc. to get it all to be stable on its own (first print, some of the parts didn't fit.. made them slightly bigger and they got sloppy... have to find that happy middle..
most of my printing problems is that my printer tends to the dimentions of things off ever so slightly... so for example a part that should have a 10mm hole in it, I have to make the hole 10.25mm so it prints at 10mm. This is rather random to some extent and not just a general scaling issue. Perhapse slowing down the printer and spending a good chuck of time tuning it, _might_ get me more dimentionally accurate prints... but when we are talking errors this small, I don't know that spending that time will actually gain me anything.That is why Tom went to the later model he developed.
The ESCs definitely are on the heavy side (don't need the BECs and could do without the connectors, etc and I believe they are a bit over speced for the motors). This is rather unfortunate as there isn't a whole lot of weight to be saved on the electronics as it stands and that is where the majority of the weight is currently coming from.
It might be worth checking the weight of a box tail boom made of foam-board as that might be able to save some mass over using the wood rod, but wouldn't be as strong. (I think this could save 10g over the wood rod).
The wing is the majority of foam in question, which will be about 35g if I did my math correctly, the tail will be ~10g of foam, 5g for the FPV camera... which leaves 0g for the power pods, push-rods/etc. With some creative work, I might still be able to pull off close to the 400g goal.
thanks, if I get this airborn and want to keep working on it (getting it down to 'exacting' measurements), that will be helpful.https://www.racedayquads.com/collec...oducts/spedix-20a-esc-lite-dshot-600-blheli_s
4 grams. In addition to being heavy and having dumb 7805 BECs, I'm not sure if the FT ESC supports anything besides standard 50hz pwm. That isn't ideal from a fc/stability control point of view. Any kwad pilot will say Oneshot125 is like BARE minimum but dshot is easier especially if you have several.
I looked up some carbon fiber stuff and was having trouble finding the size/strength/weight ratios I needed... and the wood rods were handy.Or a carbon fiber arrow shaft or tube. Every mad scratch builder should have a go-to light strong composite hollow rod.
absolutely.... I am interested in what happens with remote ID... because it might make or break this project long term (250g seems to be a challenging mass point for something like this, given that many things don't scale linearly with size.)I've been building some boats recently. Just ladling on epoxy with no regard to weight. It's awesome. But I have two of those FT1806s on the way and this thread is interesting to me.
Yeah, definitely harder than just a vanilla airplane. I'm thinking I might build one with ducts and stubby wings, sort of avatar gunship style. It'll be an interesting project and can be tested indoors. Besides the FAA I'm also dealing with winter here.
