animalshortening
I am going to get the Dream Flight Libelle and don't want to use the receiver battery for it because of its 31-gram weight. I assume that I can get a lighter set up (in terms of weight) then that by using a lithium polymer battery and a uBEC. Does anyone have any suggestions as to how I should set up the Libelle using a lipo- BEC setup? Would a lipo battery and BEC be lighter than the reciever battery? I want the battery to be as light as possible but I also want it to be able to power the glider for least a couple of hours. I also want to use the lightest possible BEC that can still maintain the power flow. Any suggestions? The link for the libelle and the receiver battery are below. Thank you.
http://www.hyperflight.co.uk/products.asp?code=LIBELLE
http://www.hyperflight.co.uk/produc...ame=dream-flight-300-mah-nimh-libelle-battery
