Hondo76251
I was just using the 3 view on the first DO 28 i did and my first fuselage ended up way too wide also, they're fatter than they look lol
Ya its square but it looks wider. Rounded corners would help, but the helicopter front is just not gonna be pretty no matter what.I was just using the 3 view on the first DO 28 i did and my first fuselage ended up way too wide also, they're fatter than they look lol
Thanks! Ive read through alot of your projects, but I must have missed that one. Very interesting!
I wonder if I should set up triple rates on the throttle and maybe not on elevator? Ive got a new radiomaster that Im still learning how to program.
Im going to try to convince my thumbs that this is not a VTOL. Ill have to start with some speed and gradually get slower as I get more comfortable with it.
This is exactly how my project turned into a CL84😂, and down the road of coding and such... then right back to good ole Stol planesYou hit the problem right on when you stated that the elevator/rudder has no flow/very little when the flaps/motor/prop are deflected down. Somehow you need to address that issue. Exploring VTOL and it's problems, when your flaps are partially down and if you apply differential, you change, maybe help yaw, it will induce roll because of the uneven thrust.
Well it flies. Rudder is too small and I think the thrust angle in relation to the flaps might be way off. But thanks to the beans the damage is minimal. I had the motors limited to 75% didnt miss it lol.
The first flight I threw it out over the beans just in case flaps up. After the botched landing I tried taking off with flaps down about 30 degrees and thats what you see in the gif flipping over with well below half throttle. I think the thrust angle is very far the wrong way. It did take off from the ground with flaps up after but its not as funny.How did you get it launched?
Freaking awesome! I guess I gotta build one now🤷♂️Finally programmed the differential thrust with pots to adjust the weight 0 to 25. It took hours to figure out but it looks so simple now. I was excited to try it but I had the wiring wrong and had to just fly without it. I changed the thrust angle to 110 degrees off the bottom of the flap from 90 and WOW that made it perfect. Very little elevator change to keep flying straight but it slows waaaay down. Im kicking myself for not taking video but I guess its fine. I made a nice landing with half flaps after about 8 minutes goofing off with loops and stuff. Against my better judgement took off again and I think the power getting low caused my right side flap servo, that is chattering and questiinable, to get soft and she went down. I ordered some 17g servos. Anyway, shes all fixed up and ready to go again. View attachment 205658 View attachment 205659
"It's just a flesh wound"
Thanks! Ya its relatively simple and pretty good little flyer so far. Its very overpowered right now. I was playing with up scaling in inkscape to be better with these motors on a future one, but I like this size because it all fits on 2 sheets of dtfb. I think 1806s might be sufficiant and be fine with normal 9g servos on the flaps. As long as the max deflection is like 50-60.Freaking awesome! I guess I gotta build one now🤷♂️
Thanks. Thats another cool plane I had never seen. I think that would probly take care of my tip stall problems. Id need to find some small really low kv or gear reduced motors...For STOL ideas, found this plane which gives a lot of info on design (3 degree on wing ) and how to fly (60% of power on approach).
Interesting, props in front traps air under wing giving it plenty of positive pressure, your prop in rear doesn't trap enough air under flap I think.
I have a YC-14 transport wing with EDF's above using blown air deflected down when flaps(exploring length and deflection angle) are extending. Wow , what a difference. Going to try things like shown on video for t/o and landings. Lost a lot of aileron power for turning. Using yaw diff plus elevator to fly.
I did a bunch on blowing and suction on the wing itself to try to get laminar flow extended. I even increased hole dia size(as I went out) on a balsa covered wing using a fan(reversed polarity) in the center wing. Result was too much battery weight was needed to get an appreciated flow for any results.
