Durafly Spitfire
fliteadmin
Administrator
Admin
The Supermarine Spitfire, made by Durafly (a Hobby King brand), is a beautiful warbird that is just plain fun to watch as it flies by! Josh Bixler talks about the retractable landing gear, durable construction and scale appearance while Josh Scott gets a little stick time. Don't miss this episode of Flite Test or all of your RC buddies will make fun of you.
Please note: You need a 6CH RX or a servo reverser to get the landing gear to work properly.
International Warehouse:
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=10778&aff=247441
US Warehouse:
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=14513&aff=247441
FROM HOBBY KING'S WEBSITE:
The Durafly SuperMarine Spitfire 1.4M is a large scale, high quality <span style="text-decoration: none; border-bottom-width: 1px; border-bottom-style: dotted; border-bottom-color: rgb(0, 255, 0); cursor: pointer; " data-mce-style="text-decoration: none; border-bottom-width: 1px; border-bottom-style: dotted; border-bottom-color: #00ff00; cursor: pointer;">EPO</span> model, and includes steerable tail wheel, Shock Absorbing Retractable Landing Gear.<br> Due in part to its large size, the SuperMarine Spitfire has excellent flight characteristics making it a great plane for beginners &amp; intermediate pilots. Included is 6 servos, 11x7E propeller, and a large high quality 35 series <span style="text-decoration: none; border-bottom-width: 1px; border-bottom-style: dotted; border-bottom-color: rgb(0, 255, 0); cursor: pointer; " data-mce-style="text-decoration: none; border-bottom-width: 1px; border-bottom-style: dotted; border-bottom-color: #00ff00; cursor: pointer;">outrunner</span>.<br> The Durafly SuperMarine Spitfire will arrive 95% RTF, leaving only the tail pieces and wing to be screwed into place. Assembly time is around 15 minutes.
Just include your own <span style="text-decoration: none; border-bottom-width: 1px; border-bottom-style: dotted; border-bottom-color: rgb(0, 255, 0); cursor: pointer; " data-mce-style="text-decoration: none; border-bottom-width: 1px; border-bottom-style: dotted; border-bottom-color: #00ff00; cursor: pointer;">Rx</span>, <span style="text-decoration: none; border-bottom-width: 1px; border-bottom-style: dotted; border-bottom-color: rgb(0, 255, 0); cursor: pointer; " data-mce-style="text-decoration: none; border-bottom-width: 1px; border-bottom-style: dotted; border-bottom-color: #00ff00; cursor: pointer;">ESC</span> and a battery to be ready to fly.<br>Note: Tail servos have been upgraded to heavy duty 12g versions to prevent servo failure on hard landings due to the large tail control surfaces.<strong>Spec.<br> Length</strong>: 1190mm <br> <strong>WingSpan</strong>: 1420mm / 55.9in<br> <strong>Propeller: </strong>11x7E<br> <strong>Flying Weight:</strong> 1650g<br> <strong>Motor:</strong> C3542 Brushless <span style="text-decoration: none; border-bottom-width: 1px; border-bottom-style: dotted; border-bottom-color: rgb(0, 255, 0); cursor: pointer; " data-mce-style="text-decoration: none; border-bottom-width: 1px; border-bottom-style: dotted; border-bottom-color: #00ff00; cursor: pointer;">outrunner</span> 1100<span style="text-decoration: none; border-bottom-width: 1px; border-bottom-style: dotted; border-bottom-color: rgb(0, 255, 0); cursor: pointer; " data-mce-style="text-decoration: none; border-bottom-width: 1px; border-bottom-style: dotted; border-bottom-color: #00ff00; cursor: pointer;">kv</span><br> <strong><span style="text-decoration: none; border-bottom-width: 1px; border-bottom-style: dotted; border-bottom-color: rgb(0, 255, 0); cursor: pointer; " data-mce-style="text-decoration: none; border-bottom-width: 1px; border-bottom-style: dotted; border-bottom-color: #00ff00; cursor: pointer;">ESC</span>:</strong> 40A (Not included)<br> <strong>Battery:</strong> 11.1v 2200~2600mAh 3S1P (Not included) <br> <strong>Servos:</strong> 6 Total (9g x 4 ailerons/rudder/elevator) (20g x 2 retract 180deg)
<strong>Battery compartment size:</strong> 150 x 55 x 32mm<strong>Required.</strong><br> 40A Brushless <span style="text-decoration: none; border-bottom-width: 1px; border-bottom-style: dotted; border-bottom-color: rgb(0, 255, 0); cursor: pointer; " data-mce-style="text-decoration: none; border-bottom-width: 1px; border-bottom-style: dotted; border-bottom-color: #00ff00; cursor: pointer;">ESC</span><br> 5ch <span style="text-decoration: none; border-bottom-width: 1px; border-bottom-style: dotted; border-bottom-color: rgb(0, 255, 0); cursor: pointer; " data-mce-style="text-decoration: none; border-bottom-width: 1px; border-bottom-style: dotted; border-bottom-color: #00ff00; cursor: pointer;">Tx</span> &amp; <span style="text-decoration: none; border-bottom-width: 1px; border-bottom-style: dotted; border-bottom-color: rgb(0, 255, 0); cursor: pointer; " data-mce-style="text-decoration: none; border-bottom-width: 1px; border-bottom-style: dotted; border-bottom-color: #00ff00; cursor: pointer;">Rx</span> (aileron/elevator/rudder/throttle/gear)<br> 11.1v 2200~2600mAh 3S1P Lipo
*Note: This model has a wingspan of 1.4m, it is noticeably larger than a normal foam plane. Due to the Spitfires elliptical wing it has a tendency to tipstall, however Durafly designers have created the model with 2 degrees of wing-tip washout to help prevent this phenomenon.
I appreciate it when Josh Scott gets stick time. Josh Bixler has been doing this so long, it is not possible for him to fully understand what a newbie does not yet know. If Josh Scott can't fly it, I surely will not be able to fly it. As Josh Scott gets more experience, you will need to find another FliteTest newbie.
You have a great project going on. I am having a blast building these planes.
Tom
