marzvt
I understand the Teksumo uses a pusher prop, but is there any reason why I cant use a folding prop like this one and mount it in the opposite orientation?
J.
You can but you have to do modifications to make it work. Trappy talks about this when he says he adds "blocks".
Remember, you are mounting these props backwards on the motor. They are designed so their spinner acts to block the prop from over extending under torque. since you are mounting it backwards on the motor, you can't use the spinner so you need to fabricate something that does the same thing. I am doing this to a prop right now because I'm sick of breaking motor mounts. I will post it when I am done.
