ItMightFly
So, trying to put a Superbee together, and getting ready to maiden. One slight problem, I can't figure out how to mix two throttle inputs. Being new to mixing channels, I don't think I have it right. I open the Adjust List, click on my MIX 1, then set it to look kinda like this:
THRO-> GEAR ACT
RATE D +100% U+100%
SW ON TRIM INH
I have one throttle channel plugged into the receiver as (obviously) Throttle, and the other as Gear. All that happens is when I flip the GEAR switch, is one motor spools to full throttle, and the other idles. When I throttle up, the other spools up and one idles (unless GEAR switch is flipped). Thanks for the help! Hope to get this bee in the air soon, my airfield is having a Fun Fly, hope to fly then. Once again, thanks!
THRO-> GEAR ACT
RATE D +100% U+100%
SW ON TRIM INH
