Hi guys n' gals
I have been trying to set up my Eachine 250 racer using a Frsky X8R reciever and the Taranis X9D-plus (not sure if that is relevant) In Libre Pilot, following the wizard I get to the point where I have to plug in the battery, and then two of the ESCs keep beeping, at irregular intervals. I have tried disconnecting, starting over, new firmware, but it is the same result every time I get to that point. (The Taranis is not connected at this point)
Has anyone else had this problem, or have I made some noobie mistake? If the later is the case, feel free to point and laugh (as long as you supply a solution)
Krise
Krise
