I need help with the set up of my qx105 with flysky 6i. It originally bound to my transmitter and seemed to be working but my computer wouldn't recognize the quad until I flashed the firmware I unfortunately wasn't thinking and now I don't have the original Backup. I have gone through the manual and all the settings both in beta flight and the transmitter several times and can't get the flight controller to arm the quad.
Please help!! Thanks!!!
I ran into a similar problem with my QX95 (if I recall it is the same cli file). Anyway, after going through all of the settings and not finding any problems (but it still not working), I copied the original CLI file, which really looked the same, and everything worked again. It may be worth it to see if you can download the original file; although, if you flashed it with Betaflight the settings might have to be different. Mine was showing the same problem as yours, but with the original Cleanflight.
If the cleanflight dump will work on betaflight it is worth a try. I've never done it so I can't say. Maybe someone has a working betaflight dump they can send you.
