Hello,
I am new to building a multirotor so please help me understand what the problem I'm experiencing and how to solve it as I'm still lacking some understanding.
I am using Turnigy 25A Plush ESC with HK 3.0 Flight Board.
Before I had calibrated my ESC with my tx, my motors would start at slightly different throttle inputs.
I then proceeded to calibrate each of my ESCs connecting it to ch3 of my rx, turning my tx on with full throttle, plugging in the battery, waiting for 2 beeps then lowering the throttle stick all the way down. I heard the confirmation beeps and tested each motors out. They were all working connected directly to the rx ch3.
However, once I connected the ESCs back on to the flight board, after the 123 beeps and another 1 beep, quick beeps continued on.
I've been trying to figure out what this quick beeps meant and I've read on the manual that quick constant beeps meant the ESCs are telling me that the throttle is not at 0.
So I've checked to make sure the subtrims are at default and the end points are at 100/100 on my tx.
Before I calibrated my ESCs, there was no problem with motors running (the only problem was that they were all starting at different throttle range). My thought is that since when the ESCs are directly connected to the rx, they work fine, it has something to do with the min throttle parameter on my flight board.
I've flashed the board before with the tricopter configuration but I doubt this is the problem since it worked before I calibrated my ESCs.
Please help me figure out what is wrong with it and help me solve this problem!
