That looked like an awesome flight, flew just like mine. Better then your Spit maiden and it stayed out of traffic lol.here is the video taken this morning ...
Any pusher which has the top mount for the motor will have some down thrust pointing at the center of the wing for the most part. On lauch they will dive for the ground until the wing produces sufficiant lift. The C pack worked great on the explorer and the bronco. Might just be the prop...I haven’t read this all this thread, but I thought I might bring up an issue I had with the explorer while scratch building it. On the plans, the thrust angle for the ft elements simple firewall must be wrong. I have built that thing time after time but until I gave it a significant amount of up thrust, it wouldn’t fly at all - even on a c pack with 3s. Anybody else have this issue or experienced something like it?
I tried it many times, and it did fly - at full throttle with the c pack on 3s but it was so bad I could hardly keep it in the air. Any time I tried to get it to gain altitude, it would just stall. I then took my scout powerpod and skewered it on with a 10 inch prop with a bit of up thrust, and she flew like a dream!Any pusher which has the top mount for the motor will have some down thrust pointing at the center of the wing for the most part. On lauch they will dive for the ground until the wing produces sufficiant lift. The C pack worked great on the explorer and the bronco. Might just be the prop...
That's awesome man, I did enjoy the Explorer you graciously donated to me, it started a whole new chapter of pushers for me which will be revisited at some point in time. I will take a Sea Duck if you are looking to donate those as well... JKSo I have a new student and decided to get a new explorer together. In order to save time @Photo001 came over with his partially built explorer last week and we pretty much finished it and built a new trainer wing. While waiting for paint and glue to dry on that one I started building 2 more (mostly using white gorilla glue). So that is 3 all at the same time. Maidened the trainer today, flies ok for a trainer in wierd gusty winds.
So of the other 2, one will be mine and identical to the one that started this thread (paint and all). I am making sure the boom can be extended for when I put on the 72" wing (lazy powered glider days), and moved in for the sport wing.
There is something to be said for the explorer, just a nice flying plane. I doubt I will fly mine all that much, I have my timber X on floats and 2 new seaducks under construction. Who knows, maybe I give it away to another newcomer again!
The timber does amazing! It does change a few things, like inverted flat spins are a real effort. Landing and take off is way better then a plane on ski's, more surface area, none of that evil of a ski digging in. Of course it is a timber X, so it still has a take off of about 6" and short landings when you want.That's awesome man, I did enjoy the Explorer you graciously donated to me, it started a whole new chapter of pushers for me which will be revisited at some point in time. I will take a Sea Duck if you are looking to donate those as well... JK
I have the Sportster on floats and haven't flown it in that configuration yet, still waiting on the prop in the mail. How does the Timber do on the floats in the snow?
This not only flew good (what I saw)... but she looked GREAT!! 👍👍here is the video taken this morning ...
Well it sure looks good 👍👍!! Probably level.@PoorManRC ...paint for the most part ,core was taped from the original (explorer core) everything else was painted ,then laminated...
I bought the speed build kit for the Explorer and the second flight at sunset last night was the best flight I have ever had. The thing is on rails when It's calm, what a joy. Odd thing, I fly with a 2200 3s and it is as far forward as the nose allows but the cg is spot on, just a titch nose down like Mr.Bixler suggests. It's my 3rd FT swappable along with Simple Cub and Fiesler Storch. Just ordered the the Old Speedster and a b power pack and 5 pack of power pods and firewalls. Bronco coming next payday. Already fixing the Storch...HEH . What the pods are for, totalled the original and 15 props coming from China. Am I ever glad my o'l lady is a cool chick. =)The original Explorer I got from Headbang, I think he used a 3000 mah 3s, which placed right to the front of the battery tray balanced perfect. I have 2200 mah 3s which I had to add nose weight, a 3/8 bolt with 4 nuts screwed on glued to the bottom of the battery tray. A 5000 mah 3s would be more then enough and give you like 20 minutes of flight time.
Cool. You will like the old speedster - it’s a fun plane!I bought the speed build kit for the Explorer and the second flight at sunset last night was the best flight I have ever had. The thing is on rails when It's calm, what a joy. Odd thing, I fly with a 2200 3s and it is as far forward as the nose allows but the cg is spot on, just a titch nose down like Mr.Bixler suggests. It's my 3rd FT swappable along with Simple Cub and Fiesler Storch. Just ordered the the Old Speedster and a b power pack and 5 pack of power pods and firewalls. Bronco coming next payday. Already fixing the Storch...HEH . What the pods are for, totalled the original and 15 props coming from China. Am I ever glad my o'l lady is a cool chick. =) View attachment 149400
THAT'S 90% of the battle!!!........ Am I ever glad my 'ol lady is a cool chick. =) View attachment 149400
Nice Storch! If you're landing gear starts popping out, glue in some paint stirrers or such over where the wires meet the fuse. It's served me well, so far.I bought the speed build kit for the Explorer and the second flight at sunset last night was the best flight I have ever had. The thing is on rails when It's calm, what a joy. Odd thing, I fly with a 2200 3s and it is as far forward as the nose allows but the cg is spot on, just a titch nose down like Mr.Bixler suggests. It's my 3rd FT swappable along with Simple Cub and Fiesler Storch. Just ordered the the Old Speedster and a b power pack and 5 pack of power pods and firewalls. Bronco coming next payday. Already fixing the Storch...HEH . What the pods are for, totalled the original and 15 props coming from China. Am I ever glad my o'l lady is a cool chick. =) View attachment 149400
If you are fairly new at flying and not over confident yet you can not go wrong with the Explorer. IMHO it is way better than the AXN floater, have gone through 2. Used the parts for the Explorer. Flies like a dream and has another wing for ailerons. Cant go wrong.Nice Storch! If you're landing gear starts popping out, glue in some paint stirrers or such over where the wires meet the fuse. It's served me well, so far.
https://forum.flitetest.com/index.php?threads/building-the-storch.60015/
I haven't built the Explorer yet. I've read both good and bad about it. It sounds like you wholly recommend it. I'll be considering adding it to my build list.![]()
