F-18 LED Afterburners
fliteadmin
Administrator
Admin
Looking to make your EDF jet just a tad more realistic in the air? Watch Josh Bixler modify this Hobby King F18 by adding flames to the afterburners! No... not real ones. But they look pretty darn real! With less than $20 in parts you can do this simple modification too. Enjoy!
nuketown
#2
Hey
I just wanted to know what I need to split my batteries power into 2- so I can also power the brushed ESC.
Oh, and how can I get the wires extruding the ESC to split into two, for the two strips of LED's?
Thanks!
colorex
Rotor Riot!
This is a soldering job, unfortunately you sound like you are not familiar with this.
But, Both ESC power cables would go soldered into the same connector, positive (red) to positive, and negative (black) to negative.
As for the led strips, you need extra strips of cable, you solder them together (positive to positive, and negative to negative) to the motor cables from the ESC. Then you solder one positive cable and one negative cable to each strip.
Hope this helps :)
ananas1301
Crazy flyer/crasher :D
#5
Yeah the suggested point of soldering...
You won´t get around that in this case.
I also just wanted to through in the word of making an adapter for this, so that you don´t have to permanently use the lights to save some battery time. On the other hand you´d have some extra weight unused. So that is up to you. If you have any further questions about what to solder where, just ask.
nuketown
#6
Hey guys
I do know how to solder. :eek:
Anyways- do you just mean solder the input wires from the Brushed ESC to the cables into the input wires into the ESC?
Thanks allot for your help.
#8
Hi all, I am considering this as an addition to my stinger however I can not find the fiberglass strands or something similar. Any sugestions or a link? :confused:
Thanks in advance
#11
Well unfirtunatly none of these items are in the US Warehouse. This is to bad now I have to think of something to add weight what do I need HMMMMM
#19
I put it on my Stinger 64 and it looks great however t did create a lot of drag at least with my model had to up to a 4 cell just to get hr in the air. Not sure why but it did non the less. Does look really cool in the sky though and yes definitly orange it does look like fire
#20
Hey Chad,
Noticed the schematic is no longer on this thread. Anyone know what might have happened to it. :confused: Wanted to refere a person to the thread as to how to hook up an afterburner mod but no good if you cant see the wiring diagram, Any help anyone may have would be appreciated.
