F/A-18 Dollar tree Build from Steve Shumate plans
Hi guys, I've loved the F-18 since I was a little boy and after building the FT F-22 and having a lot of fun, I was looking for something more. I wanted something with more of a three dimensional look. I came across the "plans" one day and I figured I'd see what I could do. The plans have the basic views, top and side so I started laying them out like a swappable build.
I started with the main fuselage. These plans have the body of the plane in two parts. I laid the side view down, traced that out. I measured the foam board to get the distance for the bottom piece. After the bottom was traced, I flipped the side and traced that. I have a template for the nose, which told me that the sides of the main fuse needed to be on top of the bottom piece. B fold style I believe.
Sorry about not posting an update. This weekend has been a rollercoaster. I worked 15 hours of OT this weekend, we had a family member pass away and a baby's christening. I did make more progress, it'll just be a couple days before I can post it
#6
I built one of these several years back... I did some mods to it to make the wing removable and did not make the forward mount strong enough and it broke in flight after just pulling out of a dive. The wing survived but the fuselage was a complete loss. I never did build another one but I still have the wing and the cutouts from the plans to build one again someday... It flew great, just keep it lite. Posting a short video and a photo of it for you... Mudman1959
#11
Sorry guys, been a rough week.
So I did the AFT section as the front. Laid out the sides and the bottom, with 3/16" space for the fold. I needed to round the back sides and the bottom so I removed the paper to curve it nicely.
I put the wing on and thought it looked "ok". I've flown the F-22 with a flat wing and it flies "ok". I thought I could put a small airfoil in the wing.
I basically did the spar at 40% and used the Versa wing design, just scaled it down to meet my needs. It's awesome to use the building skills I've learned to add to the plans.
The Spar is just one foam strip cut to 1/2" wide and a small piece at the body end to give it some taper.
I also figured I'd leave the ailerons attached. For me the paint sticks better to the minwaxed plane, so less things I have to tape the better.
AND!
I just got these from Hobbyking. I have no idea if they will even work, but I was maybe going to use them on this project. We'll see how much the plane weighs.
. . . more to come!
