Fluburtur
Cardboard Boy
FTCC'18 WWII Messerschmitt P.1110/II designed by Fluburtur
So, time to open this thread since I entered the challenge.
And this will really be a challenge, I never properly designed a plane, all my scratch built were done in one afternoon so this will be interesting.
As the title suggests I will be building a Messerschmitt p.1110/II, one of the planes designed at the end of WWII as part of the emergency fighter program. Sadly it never made it past the drawing board so informations on this model are quite hard to find, but there is at least one RC one that flies.
Scale: 1/10 (approx 80cm wingspan and 1m body)
Flying weight: approx 1kg
Speed: probably rather fast
The plane will be built out of cardboard with a hexagonal body and FT style wing, it will have either a pusher prop or EDF unit.
It uses 4 to 10 servos (4 for control surfaces, 2 for flaps, 3 for retracts and 1 for ejection seat if done)
No flight controller needed but one could be used to sequence retracts and do custom mixes.
Uses a power pack B or C equivalent (I use 4s 2200mah/2212 1000kv/8x4 prop) or 70mm EDF unit.
Could make a pretty decent FPV plane too.
BETA PLANS RELEASED HERE
