Yeah he should defiantly take that non-working software off of his site.
Sorry but I hate it when people say something like that.
I don't want to know how many hours this person worked so that you had an easy solution for a firmware reflash.
And you criticize him for doing it the correct way by putting the new software in a beta status.
So you got a free solution to a problem but unfortunately you had to do some research and use the beta version instead of searching for alternative programm, getting to know it so you could execute a flash, search for the softwarecode and adapting to the version of your chip. And because of that you critsize him?
Damn be thankful he did all that work, saved you much time and probably made even possible for you to flash something because in the other version you have to know a little bit about writing software code.
I just saw that you are in the Tricopter group. I don't know if you are setting up your first tri or not but if you want to set up your first and use the
Tricopter KK-Setup from rcexplorer.se you have to use the tri 1.6 firmware by kapteinkuk. Don't use the newer versions.
