Duck
I wanted to try a few ideas so I am going to try to scratch build a design of my own. I had a couple of questions and I could use some input.
My general idea was a twin boom pusher with an F-pack motor. My goals were to:
1) Maximize endurance. Allow adding a slightly larger internal battery then most of the mighty mini designs easily fit. A 2200 would be ideal.
2) Minimize build steps and complex shapes.
3) Be adjustable for different load configurations.
Not really original in any sense but I like bank and yank pushers. Random internet example:
https://www.youtube.com/watch?v=yj2_Esw-FhQ
The nose is going to be a simple box sightly larger then the f-pack firewall with an open front for an all in one FPV camera. Now, the questions!
Question 1: A _lot_ of designs use swept back wings. Keeping with my keep it simple plan, are there disadvantages to a strait wing? I was planning on a single strip cut the length of a single sheet of foamboard. This is a bit shorter then a tiny trainer wing. Are there drag/efficiency concerns doing this? Are these usually just to look more like a real airplane which do have to worry about this at a larger scale?
Question 2: I was planning on running 3s with a 6x4.5 prop. How much clearance from the prop should I keep the booms? I don't need alot of elevator authority so I wanted to keep it the minimum width.
Question 3: I was thinking a flat boom of 2-layers of foam, basically folded over with no gap. My guess is that it won't deal with with horizontal stress well. I wasn't planning a rudder but the vertical stablizers on the corners will induce it. A lot of twin boom planes I've seen just use a peice of wood. Is this why?
Question 4: The longer endurance foam mini's I've seen usually use 2s. Is there an inherent efficiency advantage?
Question 5: Last one, I promise. I know under camber increases lift in exchange for drag. This is great for slow flight, but does it help flight times? Can I actually use fewer watts or just use the same or more to keep lift at a wider speed envelope?
