First FPV Setup Help
saundw
I have a RangeVideo 900mHz 800 mW Video TX with a vee antenna. How should I mount the antenna for maximum results. I am putting it on a Multiplex Easystar. Thanks!
#2
IBcrazi the designer sad "Mount this with the open side of the Vee facing the nose of the airplane when flying distance as this will give a stronger signal for the return trip. Mount it with the Vee facing sideways for stunt flying As this will help keep the antenna in polarization better." so go whit that.
