Hi All,
This is my first Quadcopter build and so far everything seems to be going good. I do have a few question for the pro's out there.
I have a Acro Naze 32 flight controller and I wanted to make sure that I am hooking up my ZTW Spider 20A OPTO ESC correctly. I have all four ESC connected to the board with the orange, red and brown wire all connected. I was watching some videos out there and noticed that a lot of people seem to cut 1 of the 3 wires from all ESC except 1. My setup, I have all 4 ESC connected with all wires intact. Is this OK to do? See Picture for visual.
Next question I have is the break out cable that came with the Naze32 board. What I did, was I took the white,red and black lead from the break out cable connected it to the Naze32 then to my FrSKY D4R-II Receiver pins 2 + -. Then I took the Telemetry cable (Green and Black cable), plugged that into the Telemetry pins on the Naze32 board. Is this correct? See picture for visual.
Last question I have is the wire harness (Power System). What I did was solder all the Positive wires from the ESC's and all the Negative wires from the ESC's to a XT60 plug which will plug into a 3300mAh 4S Lipo Battery. I also daisy chained one 5v lead wire and one JST connector from the harness. I have the 5v lead plugged into the Naze32 battery connector for voltage monitor pin. See picture for visual.
Thanks to all in advance that help me clarify my setup is correct.
Specs:
Hoverthing Flip FPV Frame
SunnySky X2212-13 KV980 II Brushless Motor
Multiroter HQ Prop – Carbon Composite 9x4.5 R
RMRC 3300mAh 4S 35c Lipo Pack – XT60
Acro Naze 32 Flight Controller
ZTW Spider 20A OPTO Multiroter Simonk Program ESC
FrSKY Taranis X9D Transmitter Mode 2
RC Breakout Cable for Naze 32/Acro Naze
Specs:
