Hi all. I just finished my build of a 500mm spider quad and had a maiden flight in the snow. The flip 1.5 FC works pretty good right out of the box, but I want to change some throttle and yaw curves and adjust the PID a tad. The problem is, access to the boards USB is blocked by other electronics. There are a few solutions I have, but I question their possibility:
First, is it possible to add a telemetry module to the Flip 1.5? I see that the board has all the same pin outs that the MW Pro has for telemetry.
Second, I could raise up to FC to gain access to the USB for tuning. This however would raise the height of the FC about 1/2" higher. Will there be a significant difference in performance between a change in height of this amount?
Lastly, I may be able to access to USB right where it is if I rotate the FC 90 degrees. Is it possible to redefine what is forward for the board?
Thanks!![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks!
