I just completed building a tricopter around the electrohub kit, purchased at FliteFest 2014, and the RTFQuads flight electronics. I added some 3528 sized LED strips purchased from eBay to the bottoms of the boom for orientation / low light help.
It was mostly a straight-forward build, but I did run into a few things that might be helpful to have documented for someone else new to all this.
A lot of the information at http://witespyquad.gostorego.com/videos.html was helpful to get started, but I also think that watching youtube videos can be a little time consuming if you're trying for figure out a specific problem.
I built the tricopter using the original FT Tilt motor mount, because the "Tuff Mount" isn't available yet. I know that I could also have done a 3D printed version of David Windestals new motor mount for his V3 Tricopter, but the kit I purchased came with the old tilt, so I went with that. I had also purchased the camera/battery tray / plate -- but ultimately didn't mount it (more on this later).
The frame build was very easy, based on the FliteTest electrohub build video, but noticed that the 7/64 drill bit I initially used was just a little too small, and given I wasn't using a drill press, needed a little more play in the holes to line up the screws for both the top and bottom plates. I re-drilled the holes with a 1/8" bit, and everything was great.
I followed the advice of Alex, Josh, and Peter in the build video and soldered the motor wires directly to the ESC's. I did have some 550 cord (parachute cord which can be bought online, at Army/Navy stores, or even fabric stores) which I cut to length, pulled out the inner strands, heat sealed the ends, and surrounded the motor wires with the 550 cord sheath to keep things tidy.
The soldering was somewhat uneventful except for the desoldering of the existing motor leads on the ESC's. The wires that came with the RTFQuads ESC's are fairly large gauge 16AWG wires -- in contrast, the wires on the motors are 20AWG. It took a lot of heat from my soldering iron to get those wires off the ESCs. HINT: use a bit of fresh solder on the tip to ease the desoldering by making the heat transfer better. I noticed Peter doing that in the build video, after I had already figured that out.
I next had to decide how I was going to setup the motors. I decided to make them all counter-clock-wise (CCW) due to the fact that I had plenty of 9x4.7 CCW/conventional props and I know as a new pilot, I'll be breaking plenty of them. Using a servo tester to check the motor direction was a great idea featured in the FT build video.
After all the soldering was done, the frame completed, I secured the motors along with the Flip 1.5 flight controller and my Frsky X8R receiver onto the frame. It was at this point I put together the tilt motor mechanism, mounted that to the boom, and installed the servo, a Turnigy 375DMG (Digital Metal Gear) servo I ordered from Hobby King. I had bought two in case I broke one in a flight, but it turned out one was DOA, so I was able to use the other one which worked great.
With the servo and motor wires connected as per the multiwii docs and the rtfquads wiki, I went onto binding my Taranis X9D+ with the X8R receiver. The binding was successful, and done with the props off for safety, but I noticed that the yaw servo was moving with the throttle and realized the Flip1.5 was flashed with a quad configuration. Well, at this point, I set about installing and configuring the computer to work with MultiWii. Thankfully, I already have been using my laptop for other arduino based projects, so most of the drivers and the arduino IDE itself was already installed and working. I installed MultiWiiConfig, and downloaded the RTFQuads customized version of the tricopter multiwii 2.3 package from the RTFQuads dropbox download area. After selecting the "Arduino Pro / Pro Mini" board type, I installed the tricopter sketch without changing anything, and connected the MultiWiiConfig to the Flip1.5, and saw that everything was working normally. Even the yaw servo setting was correct based on how I had installed the servo.
At this point, I went and watched a video linked to from the RTFQuads wiki page titled "Flip 1.5 / Multiwii for dummies" to get a crash course on the multiwii config tool and see what else I needed to know. I also saw that there was a tricopter specific video I could have seen to before I started all this. Ultimately, the tricopter video would have been helpful to get me to the last step more quickly -- to realize I would have had to reprogram the flip for tricopter use. The dummies video was useful for learning about the flight modes, RC calibration and how one can power up the Flip 1.5 via USB *and* the servo rail via a battery. This is a no-no on APM, so it was interesting to see MultiWii/Flip apparently has this voltage limiting / isolation feature.
At this point, I decided I wanted to implement the ARM/DISARM function on my TX using the X9D "SF" two position switch, and the flight modes using the X9D SE three position switch. I plug additional signal wires to the AUX1 and AUX2 input ports on the Flip 1.5, and the other ends to the next available channels on the X8R RX. At this point, I thought about using SBUS or PPM, but I don't have the necessary parts for that (SBUS -> PPM converter or SBUS inverter cable -- nor do I know how that would work on a flip1.5). I'll attach a printout of my Taranis configuration for those who might be interested.
Next, I balanced the props I had, and mounted them for some prop-on bench testing. I know, it's a little dangerous, but I wanted to check to see that the yaw, pitch, roll inputs were correct. Turns out, they were. I didn't need to reverse anything on the TX nor the Flip1.5. I basically connected a battery to the tricopter, then, while holding it down, armed it, and put the throttle up just enough to spin the motors with a steady RPM. I carefully picked up the tricopter, and in angle mode, checked to see that it would try to compensate with opposite force.
OK... need to return to this at a later date... Happy Thanksgiving to those in NA!
