Nathan_116
So, I bought a used FlySky 9x used off of RCGroups, and after having my friend flash it with the er9x firmware and fixing the elevator/aileron gimbal, I started plugging in my receiver. After turning on the TX and plugging in the battery, the esc beeped like normal, but then it just kept beeping. I checked my throttle and it was down so I decided to calibrate my sticks. I unplugged the battery and calibrated my sticks, checking he onscreen display afterwards to confirm the calibration. I then plugged back in the battery and the same thing happened. After messing with the throttle, I moved around my sidled on pot, I didn't know what else's to do so I just started moving things, and all of a sudden I hear a few more beeps then thy stop. The motor then goes to half power, and when I moved the ailerons it went full. I then realized that I had plugged my battery into the wrong receiver port so I unplugged the battery again, fixed it, an turne it on. Now when I move my aileron, nothing happens and when I move my elevator it controls both aileron and elevator. I have recall rated my sticks like 4 time since and have now given up so I'm begging you all, why should I do. How can I undo this wired phenomenon???? Anything would help.
