Re-maiden of cut down 52" wing on composite fuse. Composite wing setup was 210g and had some twist in it. With foam wing it is now only 168g and seems to fly better.
@flyboa - you are the master of the air and you have proved that lighter weight really does pay a dividend (is your foam wing 1300mm)? - I think on my last build the fuse was too short - what is your typical measurement between the main wing TE and the LE of the horizontal stabiliser for you 1.5m ships?
